New garage unit
Discussion in 'Electricians' Talk' started by sutra, Mar 23, 2019.
  1. sutra
    sutra New Member
    Hi
    I've got fuses in the garage as per the attached picture. I'd like to add 1 x 1-gang and 1 x 2-gang socket in the garage, one for an automatic garage door and one for a tumble drier. From the fuseboard, there are currently 2 x individually switched lights and 1 x 1-gang socket. The garage is fed from the RCD in the house.
    What do I need to buy to replace this old fuse board thing?
    Thanks
    Cammy
  2. spirits are real 2016
    spirits are real 2016 Screwfix Select
    your garage will need to be completely rewired by a quilifed electrician you have a very old out dated system with rubber cables can you post a picture of the house consumer unit to start with.
  3. sutra
    sutra New Member
    Cheers, this is the RCD in the house
  4. ginger tuffs
    ginger tuffs Screwfix Select
    if you are asking what i need you should leave to a electrian
  5. spirits are real 2016
    the good old MK electric which was made when i worked there 30 years ago you would need a new consumer unit in the garage all new cables and have all the circuits tested by a electrician which is ment to be notified to the local council
    and i would have your house checked over for soundness of cable condition and earthing is working.
  6. sutra
    sutra New Member
  7. spirits are real 2016
    yes that would be fine but all your cables in the garage need replacing at the same time as they are rubber and will have rotted away plus you will need the incomer checked for condition and earthing.
  8. spirits are real 2016
    take a picture of the lights and sockets in the garage so we can advise further.
  9. Comlec
    Comlec Screwfix Select
  10. JP.
    JP. Screwfix Select
    Hmmmmm - even nicer if it had a main switch with two rcbo's..but hey ho
  11. Coloumb
    Coloumb Screwfix Select
    I think this is poorly phrased, it gives the impression that two rcds in series is ok.
  12. Coloumb
  13. spirits are real 2016
    I've never had any problems with one rcd consumer unit supplying another even an electrician that I've worked with used to install one supplying another without any problems and he owns his own company.
  14. spirits are real 2016
    in the description its says its a metal consumer unit.
  15. Coloumb
    It's beyond pointless and shonky practice.
    Do not do do this and don't recommend to the OP he do it.
    It is incorrect advice.
    Bazza likes this.
  16. Coloumb
    Yea weird. For sure the pics are of a placky cu.
  17. spirits are real 2016
    it doesn't look like a very nice unit it does look like its made of plastic with a metal clip that could snap hanging down.
  18. Sparkielev
    Sparkielev Screwfix Select
    BG consumer units are cheap tat and like already said 2 RCDs on the same circuit completely pointless
  19. spirits are real 2016
    two RCDS on the same circuit are pointless so why did the electrician that installed a new consumer unit in my dads bungalow also have the garage rcd one run off it and it was approved by the council.
  20. Risteard
    Risteard Well-Known Member
    No it really doesn't.
