New water cylinder leaking
Discussion in 'Plumbers' Talk' started by Scottank, Dec 26, 2019.
  1. Scottank
    Scottank Member
    Thanks! In that case, is there any downside to going manual?
  2. rogerk101
    rogerk101 Screwfix Select
    That depends on how likely you are to remember to bleed manually. The auto-bleed is working all day every day. How often were you planning to do it?
  3. Scottank
    Scottank Member
    Thanks. Probably not that often to be honest. Better with an auto vent, then?
  4. Hans_25
    Hans_25 Screwfix Select
    More to go wrong with an auto vent...manual vent is used a couple of times to bleed the system then largely left alone. Takes 5 seconds to undo/redo and see if there's any air trapped. Manual all the way for me.
