Chris_Munday
Member
Hi All,
I have recently bought a new house and the staircase was boxed in. I've removed the plasterboard wall to open the room up and I've got some stair parts ready to install. I'm stuck on how to install the newel post on the ground floor. There has never been a newel post installed, so I can't cut it and install on top. This is the first newel post the staircase has had.
In my view, I have two options:
1) Cut the stringer and first step away (so the newel sits flush with the first step) with the view of bolting the newel to the concrete floor. The problem here is that the stringer will then not be sitting on the floor.
2) Notch the newel post and the first step so the newel slots over the stringer and between the stringer and first step and then screw it to the stringer with plenty of screws. But with this, I'm worried there will be a lot of flex in the newel and if someone grabs the top and swings on it like a monkey to run up the stairs quick (kids!) it'll rip the staircase apart.... or will it be strong enough?
below are some photos. Any help or advice greatly appreciated.
