Hi… I recently fitted a new ceiling light that had earth wire attached to the fitting, all went well, I then got a wall light and in the instructions it says all units with earth labels must be earthed, it has a earth label but only the live and neutral wires, should it have come with one or is it a defect?? Any advice appreciated thanks
The metal tab you can see sticking out should be connected into the earth terminal. There looks to be a dimple at the end where the screw was.
The centre connection on that connector block should be on the tag which is attached to the centre nut, your earth wire then goes into the block.
