no hot water
Discussion in 'Plumbers' Talk' started by thomas banks, May 14, 2018.
Tags:
no hot water from tap
  1. .
    0 vote(s)
    0.0%
  2. .
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. thomas banks
    thomas banks New Member
    i have just put in a en suite but dont seem to be getting any hot water from the basin tap , when i open the tap it doesnt trigger the boiler into life, but when i remove the tap and turn the isolatern on the boiler kicks in , i thought it was a dodgy tap so i connected my new kitchen tap but still the same no reaction from the boiler
  2. I must be sad
    I must be sad New Member
    Hi
    Just for clarification! You have a combo boiler yes?
    Do you get any water out of the tap at all?
    Did you use the same flexi hose for tests on both taps? If so is it clear? Blow through it...
    Is the cold ok on the tap that doesn’t work?
  3. dcox
    dcox Active Member
    Are you getting much (cold) water coming through your tap? It does sound like there’s not enough flow to trigger the boiler as you seem to have worked out. Is your new pipework all 15mm?
  4. thomas banks
    yes all 15mm ,
    and the flow is brilliant ,
    combo boiler yes?
    no differant flexisn as differant sizes for the two taps
  5. dcox
    dcox Active Member
    Can you upload a pic of the pipework under the basin showing the isolators and taps please?
  6. I must be sad
    It works on the ballofix he said
    New combi’s hall sensor or flow switch will fire on about 2-3l/min
    If he’s got an old boiler with diagram or Venturi it could be many things
  7. I must be sad
    Try taking the aerator out the end of the tap spout with a spanner, if it’s too fast again it won’t work
    What boiler you got?
  8. I must be sad
    Turn the ballafix to reduce flow if it’s too fast....
    Is hot water to shower elec or boiler fed? Is that ok?
  9. thomas banks
    tried reducing flow still nothing
  10. I must be sad
    What boiler!!!!
  11. dcox
    dcox Active Member
    Someone needs a Snickers...
    I must be sad likes this.
  12. thomas banks
    it wont let me upload a picture,
  13. thomas banks
    i have a ideal instinct 24 boiler
  14. thomas banks
    im refurbing the house so no shower at moment but bath triggers boiler no problem
  15. I must be sad
    You have the hot and cold crossed you plank
  16. thomas banks
    dont think so like i said when i remove the tap and put feed down the toilet and open the isolater the boiler kicks in straight
  17. dcox
    dcox Active Member
    So something is going wrong when it's connected to a tap. Is it a mixer tap? Is the hot going to the left hand side of the tap?
  18. thomas banks
    yes its a mixer tap , so s my kitchen one and i have the same problem down there , tried switching them round but nothing until i remove the tap and then the boiler kicks in on both the kitchen and ensuit
  19. dcox
    dcox Active Member
    Are both taps new? Not really cheap Chinese ones? And you've tried the tap on both the hot and cold settings? What's above the isolators - just flexis straight into the tap?
  20. dcox
    dcox Active Member
    So, you've got 2 x 15mm pipes coming up, going into 2 x ballofix type isolators, on to 2 x flexis which are screwed into the monoblock tap. What happens if you turn off the cold ballofix and turn on the tap? Still get good flow?
