no hot water
Discussion in 'Plumbers' Talk' started by Nick1234, Aug 14, 2019.
  1. xednim
    xednim Active Member
    if cold feed connected to hot feed filling up the tank how the valve can be stuck?
  2. Nick1234
    Nick1234 New Member
    ok thanks for your advise. Ill give it ago tomorrow and let you know how i get on
  3. terrymac
    terrymac Well-Known Member
    Are you asking if mains cold water is connected into the hot water pipework ,then how does the cold water get up into the loft tank ?
  4. Nick1234
    Nick1234 New Member
  5. terrymac
    That question was being asked to xednim ,who seems to be confused Nick.
  6. Nick1234
    Nick1234 New Member
    ok thanks
  7. xednim
    if the valve is stuck it wont drive water into the tank- am I correct?
  8. Nick1234
    Nick1234 New Member
    i dont no if its stuck or not. i think ive got a airlock on my hot water after changing a tap. its been suggested it could be the gate valve when i isolated the water. ive tried blowing the p-ipe out with the cold tap but it hasnt worked. The gate valve is about 6 month old and doent feel like its got anything wrong with it.
  9. terrymac
    No ,your wrong again !!
    Mains cold water introduced into the hot water pipework would travel into the distribution pipe at the top of the cylinder and therefore up the expansion pipe into the loft tank.
  10. terrymac
    How did you connect cold to hot ,and is it mains cold water ?
  11. Nick1234
    Nick1234 New Member
    mains cold water. Took both kitchen taps off and put a flexi hose on it.
  12. Nick1234
    Nick1234 New Member
    the valve handle moves freely but dont no whats going on inside
  13. terrymac
    When you did this ,did water come out of any upstairs hot taps whilst cold was running ?
  14. Nick1234
    Nick1234 New Member
    dont think so
  15. xednim
    Garden hose an push in bathroom hot taps as well starting from lowest one
  16. terrymac
    That's odd. Try again as xednim said above. You should get water ,albeit cold ,coming out of hot taps before the loft tank starts to spill out.
  17. Nick1234
    Nick1234 New Member
    Sorry, cold water did come out of the hot tap
  18. terrymac
    OK ,unlikely that you have an air lock ,but try this to rule it out completely...
    Connect cold mains into hot pipework. Close all hot taps except one that is the lowest in the house( if kitchen hot tap is not connected and no other hot tap on a low level,then open one anywhere).Run cold water until it comes out the open hot tap ,then close it ,and open another hot tap. When water flows from that one ,repeat until all hot taps are giving cold water. Then turn off the cold mains ,and put things back to " normal".( in other words whatever you did to allow you to connect cold mains into hot pipework , put back to original state). If you now open all hot taps ,and they work fine ,you had an airlock. I suspect they will all drain out after a few minutes and then you will get nothing . That means your gate valve is stuck closed.
