No Power in Cable that Previously Powered Boiler
Discussion in 'Electricians' Talk' started by Karl Louie, Sep 14, 2018.
Tags:
  1. Karl Louie
    Karl Louie New Member
    We recently got our boiler replaced but the guys couldn't connect the new boiler to the wire that previously powered the boiler since the previous boiler and the old thermostat kept tripping the RCD. After replacing the boiler and removing the thermostat there has been no tripping but now there is no power in the wire?
    We know this since we tried connecting the wire to an extension lead like this and tried to power a light switch but nothing happened.
    Any ideas?
  2. Allsorts
    Allsorts Well-Known Member
    You tried to power a light switch? What did you expect it to do - go 'click'?
    Whoever replaced your boiler must have had a 'sparky' in their midst, so either call them back to ID the problem or - much better still - get a new competent sparky who has been recommended to you.
    This should be an easy fix - whatever is the cause.
    But I wouldn't recommend the original guy, and I think you should stop now too.
  3. Karl Louie
    I don't have any experience in electrics, but I would have thought that it would turn on?
  4. Mike83
    Mike83 Well-Known Member
    If there’s no power in the cable then it’s either wired wrong, a blown fuse, a switch off, or fault at consumer unit.
    You just hope that once the issue is discovered the electrics don’t start tripping again. Imagine if the boiler was replaced due to a fault with a cable.
    Testing the cable with a multimeter or volt meter would have been the best option.
  5. Karl Louie
    The previous boiler was over 20 years old and wouldn't turn on without some banging so a change was needed. I had hoped that I would be able to resolve this issue myself, but it looks like we would need an electrician in the end. Thank you for your replies.
  6. spirits are real 2016
    spirits are real 2016 Active Member
    i had exactly the same problem moved into a rented house quilifed electrician was called in to check the electrics out and one minute boiler was working fine when i went out got call from wife saying boiler now not powering up electrician could not find the fault told them to leave it too me found fault within five minutes and I'm not quilifed just highly experienced.
  7. Karl Louie
    How did you find the fault?
  8. spirits are real 2016
    with a multi meter what i ended up doing is taking the cable out from the FCU and putting a plug on it the electrician had disturbed a cable under the floor boards so decided it would be easier to plug it.
  9. spinlondon
    spinlondon Well-Known Member
    I’m not sure that taking Line and Neutral to a light switch is going to do anything other than trip the MCB or blow the fuse?
    How did you wire the cable to the light switch?
  10. Allsorts
    Hi Karl.
    I was being a bit flip in my first reply, but - seriously - if you need such basic guidance on this then you shouldn't be tackling it.
    I mean, you have a cable that has no power coming from it? And you are asking what to do next? Surely it's to go to the other end of that cable and check there?
    Bear in mind there are external controls associated with boilers - room stats and stuff. You need to allow for these as well, if the power is coming via them.
    You need a sparky.
  11. Sparkielev
    Sparkielev Well-Known Member
    Stick a plug on your boiler and plug into an extension lead that will get you away for now then call a sparky out, the people fitting your boiler should of sorted it, they should of left you with a working boiler, how did they test it if it isnt working?
  12. longboat
    longboat Well-Known Member
    Has the new boiler been commissioned, registered, and is doing what it's supposed to?
    If the answer is yes, then what is the problem?
