no power to ceiling light after changing new light
Discussion in 'Electricians' Talk' started by DaveMac54, Oct 5, 2018.
  1. DaveMac54
    DaveMac54 New Member
    I have just changed a ceiling light fitting and have no power to light. 2 cables from roof containing live, switched live and 2 neutral.Cannot remember how light was wired previously as it was disconnecte some time ago and I did not make a wiring diagram.
    This fitting is end of loop light but cannot remember whether light is connected to switch live or live. I see 2 live cables were twisted together but cannot remember if switch live was in same connector block as live cables.
    Any help appreciated as to whether live and switched live are twisted together and then light live will be connected to live/switched live .
  2. masterdiy
    masterdiy Active Member
    DM, Put a picture up so the guys can help you more.
  3. DaveMac54
  4. terrymac
    terrymac Well-Known Member
    With the power switched off ,have a look at the conductors on the switch that controls your light. You will probably find a red and a black cable. The black will not be a neutral ,but is the switched live ,and is one of the two black cables at your light fitting. In order to establish which is which ,you will need a multimeter and the knowledge of how to use it safely. As you think that you have two neutrals at the light fitting I fear your knowledge of electrics is limited ,are you sure you are OK doing this ? You may be best advised to get someone competent in.regards Terry.
    masterdiy likes this.
  5. retiredsparks
    If colour coding is correct.
    Top cable should be live & neutral.
    Bottom cable is Switch feed(red) and the black marked with red tape is the switch (switched) wire.
    Check you are not clamping on insulation.
    Check the switch is working and is connected correctly (broken conductor ?)
    It' s hard to solve problems without test gear.
    Rs
  6. terrymac
    Just seen your pic ,are the two red conductors properly making contact in the connector block ? There should not be so much of the copper visible. The red tape on the black conductor is to denote that it is live ( switched live ). The other connections would appear to be made correctly.
  7. Bazza-spark
    Bazza-spark Well-Known Member
    Where are the earth wires?
    Kind regards
  8. DaveMac54
    Hi Terry
    I said 2 neutrals but realised what I had said after posting. The wire with red tape gave a reading of 30=35 using a multimeter and the other black gave no reading. Sorry for confusion.
  9. DaveMac54
    There are no earth wires visible . This is wiring from a council house from the 50's or 60's it is all to pot. This has worked fine for years until now, wish I had taken a picture before taking light down to plaster ceiling.
  10. terrymac
    What was you " reading' Dave ? Voltage ?
  11. Bazza-spark
    Make sure you only fit double insulated fittings.
    Kind regards
  12. DaveMac54
    Hi
    Thanks to everyone for your help and advice. Evetually had to get electrician in as I could not get light to work. I have done this many times before but this time it was weeks after removing light for plasters and could not remember wiring order.Big lesson learnt always take photo before disconnecting wiring.
