No water coming through filling loop of boiler
Discussion in 'Plumbers' Talk' started by Dotti, Jun 21, 2021.
  1. Dotti
    Dotti New Member
    Hi, I have a barely used Vaillant Ecotec 831.
    The pressure has dropped a bit so I went to refill it. I last did this several months ago.
    However, there were no water sounds when I turned the valve on. I unscrewed the filling loop and tried again, expecting to see water gush all over the floor. Nothing.
    My mains water is fine and I can't find any obvious leaks, so is it the valve itself somehow not working?
    If so, is there anything I can do please?
    (Normal plumber I use not answering his phone.)
    Thanks.
  2. dcox
    dcox Screwfix Select
    The loop probably has an integrated check valve that’s stuck. Could you upload a pic please?
    Dotti likes this.
  3. just pumps
    just pumps Screwfix Select
    Could well be a stuck valve, it has been known to happen.
    Dotti likes this.
  4. Mike83
    Mike83 Screwfix Select
    If it’s the built in loop it is 2 valves.
    Dotti likes this.
  5. Dotti
    Dotti New Member
    A-ha. I unscrewed the plastic turner thing which opens the valves, pulled it off and a tiny bit of plastic dropped out. A good/bad sign, I thought.
    I tried with a screwdriver and the other turning thing (what are they called?) and heard the sweet sound of gushing water.
    So relieved I need a drink. It's been a stressful few hours. Thanks, all.
  6. Dotti
    Dotti New Member
    Btw, the part numbers inside led me to a single Amazon listing, and they're called 'service valve handles'.
    I dodged the 'Zon and found them (a pair) at City Plumbing for £6.47 delivered.
  7. Dotti
    Dotti New Member
    Interestingly, the replacement handles are metal, not plastic. Must have been a problem that I'm not the first to have. The metal handles give a much more positive turn. All sorted now.
    My next task is finding the tiny leaks which are causing the pressure to drop over time.
