Hi all, am planning to somehow "insulate" a party wall between a pair of semi's to assist with noise reduction. The wall in question is a bedroom wall and the neighbours can be heard quiet clearly. I know there is a noise reducing plasterboard which i can use. Are there any other ways of helping with this problem? The wall is 12 feet wide Thanks Benny
Build a timber stud wall that is freestanding - ie, its attached at the top and bottom only. Insulate between the studs with rockwool and double board with soundcheck plasterboard - stagger the joints. Try and avoid electric points in this wall - they allow sound through. Check in your loft to ensure that the party wall goes up to the roof. Or look at proprietory systems
