Not Laminate Floors
Discussion in 'Kitchen Fitters' Talk' started by jenniferbtheberge13, May 27, 2018.
  1. jenniferbtheberge13
    jenniferbtheberge13 New Member
    OK -
    Having followed all the threads on laminate floors - I'm deciding not to go for one in my kitchen.
    Instead thought of putting down MDF on the concrete and lino over top.
    What thickness of MDF should I use - I intend putting laminate down in the hallway and would prefer the kitchen and hall to be on the same level as far as possible!
    Any better solutions for under the lino?
    Cheers,
    TAngo.
  2. Astramax
    Astramax Well-Known Member
    Plywood.
  3. candoabitofmoststuff
    candoabitofmoststuff Active Member
    I'm only diy, but...
    I wouldn't use MDF... Too likely to absorb any moisture and eventually crumble.
    I'd use plywood.
    But wait for the expert!
    Regards,
    Cando
  4. candoabitofmoststuff
    Wow...
    Astramax's reply wasn't there when I started to type!
    Cando
  5. Yury
    Yury New Member
