Now TV box-Two remotes?
Discussion in 'Tech Talk' started by Rulland, Mar 15, 2021.
  1. Rulland
    Rulland Screwfix Select
    Evening all, I have a Now TV box that I want to have two remotes paired to it, is it do-able, will it work?, tia for any replies. Screenshot_20210315-215105_Google.jpg
  2. WillyEckerslike
    I wish I could help. After all the help you've given everyone else over the years you would think that someone out there was able to chip in. Good luck....
    Rulland likes this.
  3. Rulland
    Cheers Willy, appreciate the comment, I may have to try phoning them, I don't particularly want to buy a second remote to find you can only have one paired! :(
  4. quasar9
    quasar9 Screwfix Select
    In theory - as I understand it Now TV remotes use WiFi rather than infrared. Sky has an app for tablets which uses WiFi to control the sky box. Once one tablet has connected to the box, the second won’t, although it will once the first has disconnected. I know it’s not quite what you want but the underlying connectivity is similar.
