nut sizes
Discussion in 'Screwfix' started by suzukisj32, Oct 13, 2007.
  1. suzukisj32
    suzukisj32 New Member
    hello all,,,,
    could some 1 translate the nut sizes like m6,m8,m12 and so as i dont no which to order as im after 8mm,10mm,12mm,13mm and so on to fit my spanners
    thanks
  2. ШЮΩπ
    ШЮΩπ New Member
    you order nuts to fit bolts..not your spanners
  3. suzukisj32
    yes in theory
    but i needs to buy nuts and bolts but no sure which size as im used to using 10mm,12mm,13mm spanner to do them up so thats the type of nuts and bolts i need to buy etc Hexagon Nut M8 what size is that in english
    thanks
  4. Captain Leaky
    Captain Leaky New Member
    8mm thread, the head could be various sizes.
  5. CRS - Ross
    CRS - Ross New Member
    not an expert on this, but generally, on the m's - as in m8; m10 etc, the number represents the thread size. I think the m6 is about a 10mm hex head and nut, m8 is 13mm and so on. Hope it helps
    Ross
  6. suzukisj32
    thanks crs ross
    thats what i ment thanks for that
  7. Captain Leaky
    but not always! :)
  8. screw_fix_boyz
    screw_fix_boyz New Member
    hmmmm. let me think!!! i think that an m8 nut will go with a 8mm bolt, y is this so hard to understand?? learn to read a book in future
  9. Captain Leaky
    Ah yes an m8 nut will fit an m8 bolt, how astute you are
    But what size spanner do you need?
    They can vary between 9, 10, 11 or 12mmm on an m8 thread.
  10. CRS - Ross
    well said sfb, shame that wasn't the question... are you perhaps a staff trainer?
  11. ballyb
    ballyb New Member
    the standard spanners for metric threads are as follows:
    m5 nut/bolt/screw = 8mm spanner
    m6 = 10mm
    m8 = 13mm
    m10 = 17mm
    m12 = 19mm
    m16 = 24mm
  12. Seismic gunner
    Seismic gunner New Member
    An M17 spanner measures 17 mm across the flats An M19 spanner measures 19 mm across the flats ie the hole in the nut is 12 mm and across 2 opposite flats is 19 mm
  13. Wheresthisbitgo
    Wheresthisbitgo New Member
    For standard metric sizes the general rule is that the measurement of the nut (or bolt head) across flats (i.e. the spanner size) is the thread diameter x 1.5 + 1 mm, but as Captain Leaky said, not always.
