Oak Worktop Joint
Discussion in 'Kitchen Fitters' Talk' started by besp, May 24, 2010.
  1. besp
    besp New Member
    Evening all,
    I am fitting oak worktops and have an L joint to make. I am thinking about the movement along the joint and it's water tightness.
    I am butt jointing and have routed for worktop clamps. I have also cut for biscuits. I have already applied 3 coats of danish oil all round and plan to apply another 2 to the top surfaces when finished.
    So 2 questions:
    Do I glue the biscuits or leave loose?
    Do I use silicone or some other jointing compound along the joint? My main worry is how it will effect the top surface which already has 3 coats - won't sanding to remove residue cause a patchy look along the surface?
    Any other tips?
    Thanks.....
  2. mr.kitchen
    mr.kitchen New Member
    in theory you should not glue the joint to allow for expansion, but I tend to use waterproof PVA to be on the safe side.
    I'll be interested to know what others use.
  3. loosenup
    loosenup Member
    Much the same Mr Kitchen .
    I tried silicone once , but would not adhere to the oiled surface.. looked bloody awful .. opened joint and resealed with PVA.. never had a prob there
    I have thought of locking the joint up with the oil still wet .. in theory should seal the joint.. never tried that tho
    phill
  4. besp
    besp New Member
    Thanks chaps. PVA it is.....
  5. Joelp1
    Joelp1 New Member
    i spoke to a manufacturer once who recommended 'cascamite' which is basically wood glue.
    Dont overtighten the bolts as it can cause the top to bow up. Guess how i know this?! :'(
    If you have to sand it a lot you can even up the colour with a few coats of oil.
  6. clarky74
    clarky74 New Member
    I do not oil the two edges to be glued- no point. If you use waterproof pva and plenty of it this will seal the join and dries clear so fills any minor imperfections in the joint. When glue dries I then sand the join perfectly flat with orbital sander then apply top coats of oil.
  7. MasterSplinter
    MasterSplinter New Member
    I agree with clarky, i never oil the joint edges.
    i do insert biscuits but dont glue them.
    Have used both silicone and pva to seal joint, never had a problem with either.
