odd sized tubular latch required
Discussion in 'Other Trades Talk' started by sally green, May 18, 2019 at 12:10 AM.
  1. sally green
    sally green New Member
    Hey
    I posted on the carpenters forum but not got the help I required.
    Flats fire door that is about 42mm thick. Problem is the lockalble mortice lock/handle, To open from the outside a yale type key. To lock/open from the inside you have a turn latch that opens/locks the door. The
    tubular latch sticks and want to change this. But odd sized EG 113/114mm long overall and to the centre of the spindle hole is 95mm. Even rang locksmith, no joy.
    Standard spindles overall length are about 64/75/95/125 - I need 113/114 and 95mm centre of hole.
    Image below of the type of item I need. Btw, if I was to have a completely new lock/handle/latch fitted, this would not cover the existing hole in the fire door
    https://www.e-hardware.co.uk/standa...Lk6qEpLCMFX3FWtb36yBxu0uk6V74vMMaAtFjEALw_wcB
    Thanks in advance and I am desperate for help.
  2. chippie244
    chippie244 Well-Known Member
    You got all the help we could give on your first post.
  3. Astramax
    Astramax Well-Known Member
    Google or contact this company: for, Complete Deadlock Bolt and Turn, ref DCCBL/P, £19.96 available in satin or chrome.
    'e' Hardware
    Unit 1A, TeyBrook Centre
    Brook Road
    Great Tey
    Colchester, Essex
    CO6 1JE
    Tel 01206213499
