Old square style MK plates and Wylex MCB's
Discussion in 'Electricians' Talk' started by Wheel-nut, Mar 27, 2004.
  1. Wheel-nut
    Wheel-nut Member
    Is there anywhere where I can get a couple of the older style square MK Switch Fuse plates. I am trying to match the existing plates in my Kitchen without replacing the lot with the new style.
    I also need a couple of the older style push button Wylex MCB's; 30A or 32A and 40A or 45A.
    If any of you have these kicking around, I would be happy to pay a fair price and postage
  2. big all
    big all Screwfix Select
    heelllooo wheel nut
    can you not rob them from somwhere else in the
    house and replace those ones instead
    big all
  3. Milton Bradley
    Milton Bradley New Member
    Wylex still make modern direct equivalents to their old plug in type MCB's, but they have levers on the front now, instead of buttons, you should be able to get them from better electrical wholesalers.
  4. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Evenin' W.N.
    Why you putting in older circuit breakers? you on about the BS 3781's which are replaced by 60898's
    They will probably look ok to match what you got,but make sure you know the history of where they have come from and have not interupted a higher breaking capacity than what they were desigend to.
    The push button 3871's had a PSC of 3KA anything higher than this will render the internal mechanics N.F.G.
    So make sure there ok m8
    SF
    P.S. I changed a CU the other day and that was an 8 way wylex board with push button cb's,but lobbed the lot as I cannot use them on someone else's installation because,well,I aint supposed to.
  5. ChubbyPhaseWire
    ChubbyPhaseWire New Member
    Evenin' W.N.
    N.F.G.
    SF
    P.S.
    P.P.S
    PSC?
  6. sparky Si-Fi
    You got MSN chubs,would love to have an indepth chat with ya m8.
    you can reach me on jlp1968@hotmail.com
  7. ChubbyPhaseWire
    with ya m8.
    NOT YET BUT I GOT A PHONE GIVE ME YOUR NO AND I WILL CALL YOU
  8. ChubbyPhaseWire
    with ya m8.
    ss sent you email no C ok
  9. Wheel-nut
    Wheel-nut Member
    Hi Guys, Thanks for the suggestions...
    Big All, I can only rob one from the Living room. We built this house in '76 when Bldg regs insisted that you have a 3KW electric fire point in the Living room despite having CH! I have already put a single S/S on that outlet so I could replace the FSU with a 20A switch. p.s. Are you somewhere in the West of Scotland? I can see Rothsay from my window.
    MB, Yes, the lever MCB is an option. I may replace the whole lot if I can find a full set.
    S. Sifi, Thanks for the caution... I am considering replacing all of the MCB's if I can get a full set. The push button ones are a pain because it is easy to bump the board and trip them. I fitted a recesses bar across the trips to avoid this hazard 28 years ago! Tey have done well.
    CPW, If I had better timing I could be a stand-up comic wot! B**r
    [Edited by: admin]
  10. Wheel-nut
    Wheel-nut Member
    Hi again guys,
    Are the GE Mini Trips compatible with the Wylex Plug-ins? I noticed that Screwfix stock a 45A GE Mini Trip but the Wylex range only go up to 40A.
    Any opinion on which make is the better? I have always trusted Wylex.
  11. ban-all-sheds
    ban-all-sheds New Member
    Why on earth have you got switchfuses in your kitchen?????
  12. Wheel-nut
    Wheel-nut Member
    Hi B-A-S,
    One for the Trash Masher and one for the Cooker Hood. Both are fed from the Ring.....
  13. sparkedout
    sparkedout New Member
    I think your talking about fused spurs lots of wholesalers sell cheapo old fashioned MK lookalikes theyre all fine and match in quite well
  14. ban-all-sheds
    Madness.
    Why don't you use FCUs?
    Surely something like this: http: //*********************
    looks a lot better than this: http: //*******************
    [Edited by: admin]
  15. Wheel-nut
    Wheel-nut Member
    Yes, I should have been clearer. I am talking about Switched Fused Spur plates. Thanks Sparkedout
  16. Wheel-nut
    Wheel-nut Member
    b-a-s, Yes, that's what I need but it's going into a woman's domain and to them, shape and size matters! I would put anything in as ling as it had the MK logo on it.
  17. ban-all-sheds
    http:// ************************
    [Edited by: admin]
  18. sparky Si-Fi
    Hello again,
    Just had a squizz at the appointment book (dosent that sound like a hairdresser!)I got another CU change Wednesday and am pretty sure they have 3871 push button CB's you can have em if you want,no charge for em as I would be lobbing them in the skip.(the P+P would be nice though)
    if you want to drop me a line with an addy
    jlp1968@hotmail.com
    Cheeeeers
    SF
  19. Wheel-nut
    Wheel-nut Member
    b-a-s, you just got me a clip 'round the ear! She says it matches neither the plates nor the tiles!
  20. sparky Si-Fi
    chat
    with ya m8.
    Got your mail Chubs,will b in touch...;)
