What is the easiest way to remove old tile adhesive from the tiles, without scratching the tiles. Is there a spray that i can use. Thanks
take it, that you've got sticky on the glaze not the biscuit then? its probably grout, try soaking it with water repeatedly and using a razor scraper, good luck, no easy thing to do...;-)
