A wallpaper Im looking at hanging has the following description on the back of the label regarding the paste to be used........It has to be paste the wall/ready mixed tub adhesive/ with no PVA/PVC in the paste...........................................where do I get such a product B & Q sell the paper but not the adhesive Rang polycell to see what they say......................they dont do such a product Rang the paper designer/supplier and the phone number doesnt work Im at a loss, Ive never come across such a paste before, the paper is a flock design paper and "quite expensive" per roll..................if it cocks up I cant afford to replace the paper!!!!
Hi H&H, You can obtain the paste you require from Cole & Son. If you go to their website you can locate your nearest supplier by entering your postcode. Ready mixed tub paste is starch based and pH neutral. I don't know if your flock wallcovering is vinyl or silk (most likely to be vinyl or similar) but it is best to smooth out with a felt roller so as not to disturb the fibres.
Just been on Coles site, and my nearest supplier is only 5 mins away........................hopefully they have the adhesive I want!!!! cheers mate!!!!
Cheers for the responses, went to my local supplier today the paste was 2 years out of date but had an hour in there, talking about products etc and met a few other decorators, they all said that most of the ready mixed pastes would be fine, so I contacted customer and left it to her and she said "get on with it" so did the job and all is well!!!!!!!!!
