One pipe microbore heating system
Mancman84
New Member
Hi
Looking for some advice. Is it possible to have a single pipe microbore system?
I have a 22mm copper pipe from the boiler with 8mm upstairs and 10mm down stairs. from a manifold.
On the up stairs, the manifold has 8 x 8mm pipes, as shown in the picture 2 of each go to one radiator, as you can see in the picture.
I have small leak on where the tub is. If it is a single loop system could I take the old T connection of and put 2 push fit end caps?
TIA
Back
Top
