Only bathroom light working. No other upstairs lights. Help please.
Discussion in 'Electricians' Talk' started by Speakem, Oct 12, 2021.
  1. Speakem
    Speakem New Member
    Hi all. We only have upstairs lighting in the bathroom. Until recently our lights upstairs worked apart from the bathroom. I checked the wiring on the bathroom light fitting and pull switch. Found loose wiring at the fitting, reattached it and now the rest of the lights won't come on. My nephew is a trainee electrician and has checked all light fittings, switches and light bulbs. Power going to each one but still won't come on. Old style wiring in the house. I think it's to do with the wiring at the pull switch and/or bathroom light fittings. Can anyone help me with this problem please?
  2. FlyByNight
    FlyByNight Screwfix Select
    Trainee? How far advanced is he?
    Without giving away the possible answer.
    Ask him how he proved there was power and how he proved there was a return path? If he has a reasonable amount of knowledge then that should tell him what to look for.
  3. quasar9
    quasar9 Screwfix Select
    Have you tried removing “the lose wire at the bathroom switch” to see if other lights are restored ? This might give a clue to the cause of the problem.
  4. spirits are real 2016
    spirits are real 2016 Screwfix Select
    It sounds like a loose neutral at a celing rose or the bathroom light could be fed from the downstairs circuit and the upstairs coming separately from the consumer unit with a loose neutral in the consumer unit..
    tore81 likes this.
  5. Speakem
    Speakem New Member
    Hi there. Thanks for your reply. I'm going to ask him your questions and let you know what he says.
  6. Speakem
    Speakem New Member
    Hi Quasar9. Thanks for your help. The wiring is all connected to the light switch. Photo attached below.
  7. bright_Spark
    bright_Spark Screwfix Select
    A bit of a question which may appear silly but for a reason. Have you tried the other upstairs lights with the bathroom light on or was the bathroom light off when you tried them.
  8. Hell68
    Hell68 Member
    Sorry if you've checked already and stating the obvious but have you made sure the trip switch for the upstairs lights are back on?
  9. Bazza-spark
    Bazza-spark Screwfix Select
    Those connections need sorting as there is too much copper on show, and some not under the terminal screw by the looks of it.
    You also have only 1 wire in COM and L1 but 3 in L2. I suspect this is incorrect, and the feed to other lights/switches has been mixed up.
    How many switches control that light, are there 2?
  10. bright_Spark
    I was suspecting the same thing and why I asked if the bathroom llight was on or off when testing the upstair lights. If this is the case the other lights should come on if the bathroom light is in the on position.
  11. Speakem
    Speakem New Member
    Hi there. I've tried the upstairs lights with the bathroom light on at the same time but still not working. Thanks
  12. bright_Spark
    It is certainly looking like it is to do with what you have done, as bazza has said, the light switch looks awfully like that is at fault, I think the feed to the rest of the lights has been wired in wrongly and so you have lost the feed. Try putting all of the reds in the switch into a terminal block and ignore the switch at the moment for the bathroom, then check all other lights, they should work and that will leave your bathroom light permanantly on which is then an easy fix
  13. Speakem
    Speakem New Member
    Hi Bazza. There's only one pull switch for the bathroom and also a separate extractor fan switch next to it. The extractor fan comes on when you pull it's own switch and also goes on and off when you pull the light switch! Thanks
  14. terrymac
    terrymac Screwfix Select
    Show us a picture of wiring at bathroom light fitting. You have possibly disconnected the neutral to the other lights there.
  15. Bazza-spark
    That pull switch isn't wired correctly as a 1 way switch.
    Something definitely iffy there Bright.
  16. Speakem
    Speakem New Member
    Yes done that thanks.
    Hell68 likes this.
  17. terrymac
    Did you alter any wiring at the switch ?
    Your original post only tells us you found loose connections at light fitting.
  18. Speakem
    Speakem New Member
    Hi Terry. Pic attached
  19. terrymac
    That's the switch. I asked for pics of LIGHT fitting wiring.
  20. Speakem
    Speakem New Member
    Didn't alter any wiring at first, then my nephew a trainee sparky had a look and swapped the wires around until the bathroom light came back on. Other upstairs lights flickered and then stopped working. All light switches and ceiling roses checked and no loose wiring in any of them. Thanks again.
