Opinions on Decking Posts / Footings
Discussion in 'Builders' Talk' started by -Ozymandias-, May 7, 2019.
  1. -Ozymandias-
    -Ozymandias- New Member
    I'm building a relatively small low level deck that should be able to take a heavy load. It's between two garages and a bit of an odd shape. I've already fitted two ledgers and I've dug holes for the posts. The post holes are 700mm deep with a concrete block at the bottom. My plan was to sit a 100x100 treated post on the concrete block using additional stone / brick to fill some of the space and use postcrete to fill the hole. I've then been reading that concrete can wick the moisture out of the surrounding earth and eventually rot the timber even if it's treated. I don't want to have to replace all the posts in 10/15 years time... I've seen one option to use a cardboard former and pour a concrete footing I can then secure the post using a galvanised / stainless steel fitting...
    Secondly, most examples I've seen secure joists to the side of the posts using coach bolts, I've however seen some people either notch the post (could cause a pocket for rot) or sit the joists ontop of the posts so as to avoid a 'shear point' on the bolts and better spread the weight. Opinions??
  2. gas monkey
    gas monkey Well-Known Member
    where the post meets the base ground concrete wrap it in Denso tape and over insulating tape protecting the posts from rot
    -Ozymandias- likes this.
  3. sospan
    sospan Screwfix Select
    An alternative would be to use these. Dig a hole, fill with concrete and place these on top with threaded rod through each hole. I place a nut on either end - in the concrete stops it being pulled out and on top holds it in place.
    The advantage of these is that the ends of the post don't touch the bottom so any moisture escapes. Should the post eventually rot , it is an easy replacement
