Hello. Does anyone know the make and model of these lights. I had gone to fault find on a tripping water feature and they asked if I could replace this as most of the led lights had gone. Stupidly I didn't check if it was 240v or 12 volt. Thanks
Post a pic of the back of these lights, hopefully there will be a manufacturers label. the other way is to test the voltage supplied to these lamps or look if there is a transformer/powersupply somewhere indicating 12v it’s unlikely you will get an exact replacement of these but should be able to find one of compatible size.
