Outer ring is not working
Discussion in 'Electricians' Talk' started by Ethanpeng, Jun 24, 2022.
  1. Ethanpeng
    Ethanpeng Member
    I am using Hot Point induction cooker. Yesterday one of the double ring hob its outer ring is not on any more. Anything else I can do about it apart from calling Hot Point for help with the repair? Thanks guys
  2. Hans_25
    Hans_25 Screwfix Select
    Depends if you are able/comfortable taking the thing apart to see if there is power getting to the ring.
    Ethanpeng likes this.
  3. Ethanpeng
    Ethanpeng Member
    Which means I have to take the glass panel off to check inside?
  4. Hans_25
    Which ever way the hob comes apart...probably either power not getting to the ring, or the ring has gone pop. Else pay someone to come in and fix it. You end up paying for the part anyway.
    Sometimes its easy to take these things apart - 2 screws - and sometimes its impossible.
  5. chesterw
    chesterw Well-Known Member
    Usually hinged on the back edge, undo the front screws and the whole top lifts up, might even have a stay - like a car bonnet.
  6. rogerk101
    rogerk101 Screwfix Select
    FWIW I had an inner ring on my Miele halogen hob stop working.
    I found a good YouTube video clip on how to replace it.
    I pulled it apart to get the exact part number so I could order a replacement.
    I then reassembled it so I could use the other plates, and lo and behold, it was all working perfectly... and has been ever since.
    You may get lucky like I did.
  7. jonathanc
    jonathanc Guest
    Honestly I would either live with it or just bin it and buy a decent induction hob. Not worth the call out charge for hotpoint as in my experience the engineers are universally clueless..
    Ethanpeng and jimbobby like this.
  8. jimbobby
    jimbobby Screwfix Select
    Model number or pics ?
  9. Ethanpeng
    Ethanpeng Member
    The cheapest the repair charge can buy me a new one although not best one.
  10. Ethanpeng
    Ethanpeng Member
  11. Bazza
    Bazza Screwfix Select
    Umm. It’s been nearly a year. We thought you’d have fixed it by now!
    First point. That’s not an induction hob. Induction hobs do not glow.
    Secondly. What are pictures? I can see a hob ring that is energised. That is we what they are do when they are working.
    Ethanpeng and Bazza-spark like this.
  12. Ethanpeng
    Ethanpeng Member
    What? Mine is not induction hob? Sorry, so what it is then? Am I a laughing stock now?
  13. Bazza
    Well, I have been known to be wrong, but one of the big benefits of an induction hob is that the cooking areas do not get hot in themselves.
    Can you say what the model number is? Then I can put my mind at rest. TIA.
  14. adgjl
    adgjl Screwfix Select
    To glow that shade of red, at least that one “ring” is a halogen ring.
    Ethanpeng and Bazza like this.
  15. Ethanpeng
    Ethanpeng Member
    Hotpoint, but I don't know the rest.
  16. Bazza
    There will probably be a sticker on the underside.
    or written on the front of the instruction book!
  17. robertpstubbs
    robertpstubbs Screwfix Select
    It’s two different hobs in the pics.
    arrow and SIRJOHN19 like this.
  18. Ethanpeng
    Ethanpeng Member
    How?
  19. arrow
    arrow Screwfix Select
    Post 10 pictures are Hotpoint, post 15 is Schott Ceran
  20. Ethanpeng
    Ethanpeng Member
    I didn't give your full photo, Hotpoint is printed in the middle the glass, Scott Ceran is printed on the right corner, must be a product of Hotpoint.
