Outside drain problems
Discussion in 'Plumbers' Talk' started by illusoryduck, Nov 10, 2018.
  1. illusoryduck
    illusoryduck New Member
    Hi all,
    I've got an outside drain, that don't seem to be draining. Had my hand down the hole and can't find any outside, just feels like a bowl? If that's the case, how to I get it connected to an outlet?
    Thanks
  2. KIAB
    KIAB Well-Known Member
    A drain gully?
    Clay,plastic?
    What running into it rainwater?
  3. spirits are real 2016
    spirits are real 2016 Active Member
    what you felt is known as the u bend it will be connected to a underground pipe have you lifted the manhole cover up to check for blockages.
  4. illusoryduck
  5. KIAB
    You will find it runs into a nearby manhole chamber.
    It will be most likely identical to one below,usually find them full of silt/crud & outlet solidly blocked, or/& slow draining
    [​IMG]
  6. spirits are real 2016
    that is about right height for the water it will never fully drain away that is to stop smells coming through from drain does it over flow or just sits like that.
  7. KIAB
    Yes, spot on.:)
  8. illusoryduck
    Yeah it's not draining just overflowing. What's the best way to get it flowing
  9. spirits are real 2016
    check manhole for blockages and use drain rods down the gully have you got a hose pipe or jet wash you can stick down there under pressure to clear blockage.
    illusoryduck likes this.
  10. KIAB
    Uses rods from manhole up to gully, snake wire might work from gully end, as it's flexible enough to got over U bend.
    I've used a dustbin full of water & emptied slowly down gully here, it's usually enough force to clear any blockage.
  11. illusoryduck
    All sorted, that's for the help everyone!
    KIAB and spirits are real 2016 like this.
