Outside light
Discussion in 'Electricians' Talk' started by tore81, Aug 1, 2021.
  1. tore81
    tore81 Screwfix Select
    Hi all
    have run a cable for an outside light which will be on a PIR
    I wanted to have it on a separate MCB.
    But all MCB be taken.
    would it be ok if I double up on the mcb supplying downstairs lighting circuit. That’s the easiest and closest contact
    Thanks I’m advance
  2. Shaun Mitchell
    Shaun Mitchell New Member
    What size is the cable the mcb and the light wattage
  3. tore81
    1.0mm mcb will 6amps supplying LED, which don’t use nothing really.
  4. Xshaunyx
    Xshaunyx Member
  5. Xshaunyx
    Xshaunyx Member
    Using the same mcb as the ground floor lights will be fine
    tore81 likes this.
  6. tore81
    Thanks so it’s fine to double up in the MCB.
  7. Bazza
    Bazza Screwfix Select
    Yes, that is what he said.
    tore81 likes this.
  8. tore81
    Cheers Bazza
