outside lights,what wire
Discussion in 'Electricians' Talk' started by nancy69, Dec 13, 2003.
  1. nancy69
    nancy69 New Member
    My husband wants to put light on the side of our house,he has had a sort out in the shed and has found some orange cable which may have been left over from a lawn mower,is this allright to use for one light bulb as we have a lot of it.
    Thank you
  2. Wheel-nut
    Wheel-nut Member
    NOOOOOOO! That orange Flex does not have an earth core and is not suitable.
    I will leave the accredited sparks to follow up...
  3. nancy69
    nancy69 New Member
    oh ok,it was just a thought to use up the cable it would have been turned on and off at the plug
  4. supersparky
    supersparky New Member
    how many wires are ther inside?
    if there is 3 its ok
    if 2, then no
  5. MICC
    MICC Member
    No, please do not use this for wiring up an external light, its only use is for..well.. lawn mowers.
    Please get an electrcian to look at wiring the light in.
  6. MICC
    MICC Member
    SS, what are you thinking here?
  7. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Thats just waiting for an accident to happen,go with everyone elses comments Nancy,that flex is totally wrong for what you want to do.
  8. supersparky
    nothing wrong with it aslong as it dont go underground, is in good condition, has an earth, then its no worse than the stuff you buy at the wholesalers, no wouldent fit it for someone, but its diy mate, whatever you say they are gunna use it
    BR
  9. MICC
    MICC Member
    Hang on here, diyers are taking your advise, if anything you should be going overboard to cover yourself.
    If advise offered on this site is taken and an accident happens I am sure it will come back on you.
    Please dont encourage diyers, help them get advise from electricians....
  10. supersparky
    still nuffin wrong with using 'flex' to supply lights
  11. kesh
    kesh New Member
    I'm glad you said that because when I was a kid I used 3core "orange" flex to wire my shed. I feel happier now!
  12. MICC
    MICC Member
    So lets say they do this!
    Stick a 3core orange flex through a window vent and then clip it 10m down the external wall at waist height.
    Enters light fitting via hacksaw cutting to side of fitting, thus making it water tight fitting impossible.
    Its all backed by a 13amp plugtop.
    You could say you knew nothing about this BUT, you said a 3core flex was ok!
  13. supersparky
    they dident say how they were going todo it! i answered the question 'is orange flex ok to use for outside lights' and your disputing that it can not be used under the circhamstances that I STATED, i said it must not go underground and it must have earth....find me where in the regs it says you can not use flex for outside lights
    they did not say they wouldent use glands, simply is it sutable
    BR
  14. MICC
    MICC Member
    Yes thats my whole point...
    not having a dig here, just making sure we are covered in case some prat looks at what you have said and then kills someone.
    Flex is not suitable for running to an external light, it would have to be protected.
    I know YOU would not install it but joe bloggs will run anything if its cheap!
  15. supersparky
    i see your point
    use hituf with glands then, my preference anyway
    BR
  16. seavigil
    seavigil New Member
    Needs to be UV stable though,
    The last house we were in the Imm Htr and shower cable ran along the outside wall for about 6 m, the sheathing didn't look too pretty after 10 yrs in the sun. Oh, and the Immersion heater switch in the fuse box only hung on its wires inside the fuse box, pleased I got out of there.
    Any sparkies out there who would like to share any domestic horrors they have seen recently (no, not the mother in law) - DIY bodges you've had to put right.
    DJW
    DJW
  17. Milton Bradley
    Milton Bradley New Member
    In my previous house, the earlier occupany was mad enough to put 30A fuse wire in ALL the holders, luckily I checked the electrics on moving in, and saw the deadly mistake, promptly replaced all the fuses with the proper ratings, (and invested in a set of retrofit plug in wylex MCB's to replace the fuses in due course - felt much safer after that!).
  18. MICC
    MICC Member
    called to a road haulage company who carried out a lot of welding in their garage.
    They claimed the fuses kept blowing, so they stuck some welding rod in the fuse, well it stopped it blowing.
  19. kesh
    kesh New Member
    nancy69? Ho Ho Ho SS!
  20. sparky Si-Fi
    I have seen the replaceable trips for old wylex boards with the toggles tapped up in an attempt to stop 'em from tripping.....F**n' why?
