outside security light
Discussion in 'Electricians' Talk' started by arsenalboy, Jun 30, 2006.
  1. arsenalboy
    arsenalboy Member
    I have an external security light, 500 watt halogen. It is one of the lights that comes on with movement but also has an internal switch.
    I recently had a new kitchen put in (the light is on the outside wall) and the room was rewired, they introduced an isolating switch and fuse.
    Ever since then the light packs up at regular intervals and I have to replace it. It has just gone again and I thought I would check the fuse before putting ladders up.
    The fuse is 13 amp they have put in, is that my problem? Is that letting too much electricity through, would have thought it should have been 5 amps?
  2. JP.
    JP. Screwfix Select
    amps?
    So like if you put a 5amp fuse in the voltage drops to say 120v. Nice wind up arsenalboy.
  3. Ant1981
    Ant1981 New Member
    Rather than insults best left to the playground, lets answer the problem.
    No, it is nothing to do with the fuse. This doesnt impede the amount of electricity that comes through, it just limits the current draw.
    If the bulb is going alot, perhaps the fitting is bad or the bulbs are a bad batch. Or a fault in the wiring, would need further investigation rather than discussion.
  4. JP.
    JP. Screwfix Select
    answer the problem.
    It's a wind up pal.
  5. arsenalboy
    arsenalboy Member
    Sorry I don't understand, that is why I am asking advice(no winds up). I have always been led to believe lighting circuits are 5 amp and wall plug circuits are 13 amp and cooker circuits 30 amp etc. So if I have wrong size fuse isn't that wrong?
  6. JP.
    JP. Screwfix Select
    Your not wrong on that. It was you saying about the voltage....seems a strange thing to say and reeks of wind up material.
  7. arsenalboy
    arsenalboy Member
    Jp , I didn't say anything about voltage you did!!!
    If I gave a coded message in my question that related to voltage, that shows my lack of knowledge and my genuine request for information??
  8. JP.
    JP. Screwfix Select
    You said is the fuse letting too much electricity through....I immediately equated this with the size of fuse and the amount of voltage which in my mind rang the wind up bells. Was I silly to summise this....probably not....but then I would say that wouldn't I.
  9. sparkedout2
    sparkedout2 New Member
    the spur would be better with a 5 or even a 3A fuse this only affects how quick or even if it will go under fault conditions.
    Your not by any chance touching the lamp with your fingers when you relamp are you grab the lamp with a tissue next time.
  10. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    You should have a 3A fuse for the light.
    At least, the 3A fuse would blow before the bulb/lamp, but it won't cure the problem, just save you money.
    Mr. HandyAndy - really
  11. STGO
    STGO New Member
    this is important mate, if you touch the bulb and dont clean it properly, it will blow early. you should atleast be down to the correct fuse for your circuit, if after you replace bulb, without touching it with your fingers, it blows again you have a problem with the circuit.
  12. STGO
    STGO New Member
    the
    maybe ;)
  13. Rabbit Rabbit
    Rabbit Rabbit New Member
    lol JP. Makes ya wonder don't it m8.
  14. JP.
    JP. Screwfix Select
    you money.
    So what is the problem? An intermittent short measured in microseconds....not enough to rupture the fuse, but creating transients which will take the lamp out? Is this the answer?
  15. JP.
    JP. Screwfix Select
    Sure does mate....thats for sure.
  16. arsenalboy
    arsenalboy Member
    OK.
    I have changed fuse down to 3amp and put new 500 watt lamp in (no fingers on glass!!) but still no good. Have checked out the wiring and that is all in tact with no damp. What else is there apart from wiring, bulb and fuse? If it was a table lamp it would have to be one of those 3 things. It has a PIR but I am using the manual override. I will obviously need to buy a new fitting but I am concerned that the problem is elsewhere. Is there other stuff in these units that will pack up?
  17. HSG 52
    HSG 52 New Member
    Check the lamp packaging to make sure its 230v & not 110v.
    Its a long shot but you never know!
  18. JP.
    JP. Screwfix Select
    110v.
    Must be the above..what else could it be? Another really long shot..is there any kind of vibration vibrating the assy?
  19. arsenalboy
    arsenalboy Member
    Does anyone know whether there are other parts to these fittings that pack up. The wiring is very complicated because of manual override, are there other little bits that control this?
  20. some of these lights have a fuse on a little board inside the light, very unusual but does happen. the challanger range from cef contain such a fuse.
