Paint over spray on a acrylic bath
Discussion in 'Painters' Talk' started by ashwales, Jun 11, 2018.
  1. ashwales
    ashwales New Member
    Had a painter in and he made a right mess on my brand new bath! Whats the easiest way to get it all off?
    Cheers
  2. RolandK
    RolandK Active Member
    Depends how long it's been on there I guess. I'd try some hot water with washing up liquid and one of those abrasive bath cleaning sponges but make sure it is suitable for an acrylic bath so you don't scratch it. Failing that CIF cream is pretty good at this type of thing. Or get the painter back to sort it!
  3. KIAB
    KIAB Well-Known Member
    Get painter to supply & new bath at his expense.
    WillyEckerslike likes this.
  4. RolandK
    Good point KIAB makes.
    It's very poor attitude the painter had to your property. How long would it have taken to protect the bath? Total disrespect for your property. He might have liability insurance if you're lucky. Possibly with the OK Coral insurance company?
    KIAB likes this.
  5. KIAB
    And fit.:rolleyes::oops:
  6. Astramax
    Astramax Well-Known Member
    Have a word with my wife let! :D:p:p
  7. DIYDave.
    DIYDave. Well-Known Member
    Importantly we haven’t asked what type of paint is it ?
    Yes, realistically the painter should be dealing with this and obviously, with covering the bath in the first instance, you wouldn’t/shouldn’t be in this situation
    So emuslion from walls, ceiling or trim paint (woodwork), oil based or water based
  8. Astramax
    What colour is the paint.
  9. DIYDave.
    Me thinks ur taking the * a little bit Astra and possibly aimed at my comment ?
    Surely the type of paint is an important factor here with regards to cleaning, would you not say ?
    Colour won’t be of such an importance, the paint needs to come off regardless
    Anything else enlightening you wish to add ?
  10. Astramax
    Yes, very important, how long has the paint been on the bath?
  11. Astramax
    And what if anything have you tried to clean it off with so far?
  12. RolandK
    Yes it matters what type of paint is on the bath but also a problem it being an acrylic bath. Going to be very easy to damage trying to get the paint off.
  13. Astramax
    If the op reply's to these questions the problem can be relatively easily corrected I'm sure.
  14. Astramax
    Waiting for a reply here, has your Mrs drowned you in the bath. :eek:
  15. Wayners
    Wayners Well-Known Member
    Microfibre cloth and hot water with bathroom cleaner like cif. Steamer will work to if bad but be sensible.The trick is get it warm and it will go soft. I'd try microfibre cloth with hot soapy water with lots of elbow grease. Masking tap and plastic to cover next time . hay
    Astramax likes this.
  16. Astramax
    If it's emulsion paint splashes they can be removed with Methylated Spirit on a sponge or microfiber cloth, then cleaned up with cif.
    ashwales likes this.
  17. Wayners
    I nearly said that but it's not recommended on acrylic although I've used in the past. You got shares in Microfibre Inc?
  18. Astramax
    No, in Meths. :D
  19. Astramax
    Just going to apply some meths to my bath, probably will clean it up a treat! ;)
  20. Wayners
    Yeah. I've used as its a good cleaner. Just what I read it harming plastic. Off for swim now as that gets the paint off me :)
