Painted paving
Discussion in 'Painters' Talk' started by Joelfc89uk, Jun 9, 2018.
  1. Joelfc89uk
    Joelfc89uk New Member
    I have recently moved in to a new house and the front yard had stones all over it.
    After some investigation I found there was paving slabs under them so I have taken up all the stones and then found that some of the slabs had been painted black!!! I have tried paint stripper , scraping , turps and wire brush nothing will take up this paint does anyone have any ideas what will remove the paint?
  2. KIAB
    KIAB Well-Known Member
    You sure it's paint, most paint stripper would make some impression on the paint.
  3. Astramax
    Astramax Well-Known Member
    Can you post a photo as that may help to reach an answer.
  4. Joelfc89uk
    Yer here is one I just presumed it would be paint.
    Thanks for your help
  5. KIAB
    See what WD40 does to a small area.
    Could be a bitumen based product, jetwash any good.
  6. Joelfc89uk
    Yer tried jet wash some was coming up then whats left is the stuff that wouldn't come up, might have to just paint it with a light colour, not sure why they would of painted a floor black
  7. Astramax
    Have you tried bleach, paint one slab with Domestos laid on thickly and leave overnight, power wash it off the next day, maybe lucky.
    Joelfc89uk and KIAB like this.
  8. KIAB
    Might work,could also try a brick cleaner might remove the crud, something like Cementone a
    Brick & Patio Cleaner, this is quite mild compared to some brick cleaners.
    But, do wear gloves & eye protection if using bleach or patio cleaner.
  9. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Cost of new slabs vs cost of all that cleaner?
  10. Joelfc89uk
    Thanks I will try this thanks again
  11. Joelfc89uk
    thanks for the advice
    Thanks for advice
  12. Joelfc89uk
    Yer good idea I may price this up aswell
  13. Astramax
    Poundland:cool:
  14. KIAB
    Freecycle/Freegle.:D
    Could always turn the slabs over, if other side is smooth.:eek:
    Joelfc89uk and btiw2 like this.
  15. btiw2
    btiw2 Well-Known Member
    If the paint(?) has pententated then I can’t see any chemical fixing it.
    If it hasn’t, then angle grinder with wire (if you feel gentle) or diamond grinder (if life’s too short).
    Joelfc89uk likes this.
  16. btiw2
    Penetrated.
    Jeez. What has happened to my phone’s spell check? Piece of shif.
    Joelfc89uk, WillyEckerslike and KIAB like this.
  17. WillyEckerslike
    Have you still got the stones that you took up..........?
