Hello Really appreciate some advice here. Need to paint outside of large pebbledash house, paint blown with cracks etc that will need repairing and will be getting scaffold erected in new few weeks. Once repaired (loose material removed using jet wash), will use fungicidal wash, prime bare surfaces and finish with two final coats. Looking for the best long lasting paint to use - will be carefully prepping area and using a sprayer as cannot stomach task with roller or brush. What is the best paint to use and is water based (breathable) better than an oil based paint. I planned on using Dulux Weathershield white All season Exterior smooth masonry paint which is an oil based and quick drying which has been highly recommended (I can still get hold of this even though been discontinued). Any advice on paints and general pointers here much welcome. See pictures of damaged areas (lookslike not been primed/no stabilising solution used) Thanks Alan
