Painting Internal Door/Arch
Discussion in 'Painters' Talk' started by richo106, Jul 30, 2018.
  1. richo106
    richo106 New Member
    I am currently renovating my house and i want to paint the existing doors, i have emulsioned all the walls and has made all the doors and arch look very yellow.
    Am i correct in thinking its best to sand all the doors/arch down and then apply primer and then two coats of satinwood?
    Any tips on how the paint internal doors? whats the best brush/roller?
    Also only one of the doors the paint has flaked in a lot of areas (see pic) what would be a way to remedy this?
    All help and advice greatly appreciated
    ps i havnt mentioned skirts as i have installed all new MDF pre primed skirting so will just satinwood them after ive prepared all the doors etc...
  2. KIAB
    KIAB Well-Known Member
  3. Astramax
    Astramax Well-Known Member
    Will need an undercoat not a primer, one undercoat and two top coats, job done.
  4. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    See that is where it gets confusing. If not back to bare wood, and properly rubbed down to provide a key, surely 2 gloss(or whatever) top coats would be fine?
  5. Astramax
    Looking at those doors a dosing of undercoat would be advised after spot priming with Zinsser BIN.
    Unlike you to be confused MrHA
  6. HarDeBloodyHarHar
