Painting over damaged plasterboard
Discussion in 'Painters' Talk' started by Daniel P, Jun 6, 2018.
  1. Daniel P
    Daniel P Member
    I have some walls that I'm stripping paper from, and repainting. Only problem is that whilst stripping the wallpaper, the paper that you normally paint over is coming away also, leaving just the brown paper that you find behind that.
    I have sanded down a small section and painted over to test, and it gives a good finish, but I'm wondering if there could be any problems with painting over this?
    Thanks.
  2. Jitender
    Jitender Well-Known Member
    Hard to tell from photo, but thick the plasterboard wasn't skimmed (i.e plastered) before being papered.
    May be worth getting the wall skimmer by plaster.
  3. Daniel P
    Daniel P Member
    Yeah the plasterboard isn't skimmed. I would normally just paint onto plasterboard without skimming also, just giving it a mist coat before applying two normal coats. Can I do this with the boards in their current condition, or would having the paper missing pose some future problem?
    I'll replace the boards rather than plaster if that's the only choice...
  4. Jitender
    Does look pretty bad, not a good idea to paint on top, the papered layer provides strength to the plaster. Skimming or re-boarding is likely to best option, or wallpaper over using thicker lining paper.
  5. Astramax
    Astramax Well-Known Member
    Smooth it over with Easifil applied with a broad caulking tool, sand to a smooth surface when dry and if needed apply a second coat of Easifil and sand smooth once again. Paint over easifil with Zinsser 123 let dry and line the whole area with 1400 grade lining paper.
  6. DIY womble
    DIY womble Well-Known Member
    Vote for skimming
  7. Daniel P
    Daniel P Member
    Thanks everyone. Sounds like putting new plasterboard up is the quickest/easiest option, so I'll go with that as time is of the essence.
  8. Astramax
    Good choice on two counts, quickest and cheapest.:)
    Daniel P likes this.
  9. Daniel P
    Daniel P Member
    Mostly the cheapest if I'm being entirely truthful. I'm tight.
    Astramax likes this.
  10. DIYDave.
    DIYDave. Well-Known Member
    If your painting onto new plasterboard, no need for mist coat, just lash ur full bodied paint straight from the tub
    Your gonna be using tapered edge boards then taping and filling joints ?
  11. DIY womble
    PVA and skim , job done
  12. Daniel P
    Daniel P Member
    Exactly that yes
  13. Astramax
    Always mist coat plasterboard, dilute emulsion paint 20% for first coat.
  14. DIYDave.
    Good good ...... all good :)
    But you will need to mist coat sections of filler / easifil
