Painting plasterboard walls-Advice
Discussion in 'Painters' Talk' started by Pjclarke1978, Aug 10, 2018.
  1. Pjclarke1978
    Pjclarke1978 Member
    Does anyone have any advice?
    I am planning on redcorating my living room. I did this 5 years ago and I had issues with mud cracking on paint. Eventually I ended up using PVA to seal walls then repainting which resolved the issue. Also had issues with plaster bubbling.
    I don’t want to find myself in a similar situation again. Should I use a drywall sealer such as the gyproc dry wall sealer?. Any advice would be suggested. Heard using PVA isn’t recommended.
    Ditching the Dulux emulsion and using the Johnston’s Matt Emulsion. Which I have heard good things about and after using their aqua satin range which was excellent.
    Thanks
