Painting the caulk line on a skirting board
Discussion in 'Painters' Talk' started by Iron_Mike, Nov 4, 2017.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    I am not sure if I should be painting the caulk line the same colour as the skirting board (white) or the colour of the wall (grey)
    Is there a standardised approach or does it come down to personal preference?
    Thanks
    IM
  2. CGN
    CGN Well-Known Member
    I usually paint the caulk the same as the wall, especially if the caulk thickness varies due to undulating walls. Do it the other way, and it would highlight the ripples and bends in the walk, but when painted to the edge of the skirting, the wall will look straight to the eye.
    Iron_Mike likes this.
  3. 2shortplanks
    2shortplanks Member
    I paint the woodwork first, then cut in with emulsion. If you can get a nice straight line, it doesn't matter so much exactly where the join is.
  4. Astramax
    Astramax Well-Known Member
    Never thought about that........how much caulk are you guys using, sounds more like a filler job!:eek:
  5. nigel willson
    nigel willson Well-Known Member
    Filler will crack if used for this. Caulk only!!!
  6. Astramax
    I know that, what I am badly saying is how large is the bead of caulk if you require advice on where to paint it up to:rolleyes:!
    Isitreally likes this.
  7. Iron_Mike
    Is only a minor bit of caulk. I crush the nib end to ensure only a small bit comes out.
