Painting wallpaper
Discussion in 'Painters' Talk' started by Phil Morgan, Nov 10, 2019.
  1. Phil Morgan
    Phil Morgan Member
    Hello,
    My kitchen has sort of rubber feeling wallpaper on it - it's very old. We're going to be extending the hosue and will be redoing the kitchen so I don't want to waste much time on properly redecoratin. Therefore, I just want to paint over the wallpaper. Is this possible? And is there anything I can put on there that will do a good job? Someone mentioned putting a pva solution on first, then painting.
    Thanks
  2. Astramax
    Astramax Super Member
    Why is it always someone?...........
    If the paper is clean go over it with Zinsser Bullseye 123 and then whatever paint you want to use for example eggshell, matt emulsion etc. If the paper is greasy forget cleaning as it will come off the wall once wet.
    Phil Morgan likes this.
  3. nigel willson
    nigel willson Screwfix Select
    If it’s probably a washable paper can you not just strip of& the top layer leaving the backing paper on which you can paint
  4. Astramax
    Sounds like Nairn Contour paper.
