Palm router
Discussion in 'Tool Talk' started by mrppp, Mar 18, 2018.
  1. mrppp
    mrppp Member
    Looking for a small router suitable for door trimming, hinges etc and recommendations?
  2. KIAB
    KIAB Super Member
    AlvyChippy and mrppp like this.
  3. chippie244
    chippie244 Super Member
    same here.
    AlvyChippy likes this.
  4. mrppp
    mrppp Member
    Thanks, the colour looks like a Makita lol Do you use Makita bits?
  5. chippie244
  6. mrppp
    mrppp Member
    any 3/8" or 1/4", also can you see what you are doing with these especially routing door hinges?
  7. KIAB
    KIAB Super Member
  8. mrppp
    mrppp Member
  9. mrppp
    mrppp Member
    So to route out hinges would i need the plunge base or can depth be set on router without plunge base? not used routers before
  10. KIAB
    KIAB Super Member
    Orginally bought the Bosch palm router, but I dropped a clanger:oops:, with the guide bushes, you have to use Bosch bushes or buy an adaptor, etc, right pain in the butt.
    Was cheaper to buy Katsu, can't fault it, & witth plunge base base, it's perfect to use with hinge jig.
    You have a turret depth stop on Katsu base, allows three depths setting.
    mrppp likes this.
  11. chippie244
    You can set the cut depth without the plunge base.
    mrppp likes this.
  12. KIAB
    KIAB Super Member
    Yes, it's rack & pinion I think, but I only now use plunge base now Chips.
  13. CGN
    CGN Screwfix Select
  14. mrppp
    mrppp Member
    Thanks I,ll get on and buy one then. What 8mm router bit should i get, i assume 3/8" for hardwood door?
  15. chippie244
    Fair enough but I don't use a hinge jig or if I do I make my own.
  16. mrppp
    mrppp Member
    Bought one Kiab, hopefully have it tomorrow. Bought a trend bit from SF ( thought they might throw in a free router given the price!) My tool collection is getting too big for the garage.
  17. KIAB
    KIAB Super Member
    Your tool collection can grow at an alarming rate.:D
  18. mrppp
    mrppp Member
    I have genuinely bought tools I forgot I had!
  19. KIAB
    KIAB Super Member
    Your not the only one,had a light spring clean in workshop last month & I found tools & things I can't even remember buying.:(
    Dread to think what I will find when I venture deeper into the back of workshop & start looking in crates,etc.
  20. mrppp
    mrppp Member
    So got router, but the bit i bought when inserted is too long for cutting hinges at maximum adjustment. Can you get shorter bits? Mine total length including shank is approx 60mm
