Palm router
Discussion in 'Tool Talk' started by mrppp, Mar 18, 2018.
  1. KIAB
    KIAB Super Member
  2. mrppp
    mrppp Member
  3. mrppp
    mrppp Member
  4. KIAB
    KIAB Super Member
    6mm :confused:, the one you linked to, was 6.35mm(1/4") shaft.
  5. mrppp
    mrppp Member
    6.35mm then lol all SF are extra long shanks
  6. mrppp
    mrppp Member
  7. mrppp
    mrppp Member
    Nice Router BTW so appreciate you mentioning it
  8. mrppp
    mrppp Member
    Bought the plunge base to go with router. Made it so much easier especially with door hinges.
  9. KIAB
    KIAB Super Member
    Said that on page, you can set turret depth stop to thickness of hinge being used.:)
  10. KEVIN NAIRN
    KEVIN NAIRN Member
    I hang a lot of doors, and use a 46/913 top bearing guided router cutter. It's 12.7mm dia x 12.7mm long. I have my own hinge jigs which are made from 15 or 18mm birch ply with a 102mm long x 50mm wide rectangular hole cut in it. I use 4 jigs: 1 for the doors for 75mm hinges, 1 for the frame for 75mm hinges and the same for the 102mm hinges. I used to use a Bosch 110volt palm router, but now use the FANTASTIC Bosch 12volt cordless router. No more carrying around heavy router with ******. The Bosch 12volt planer is also FANTASTIC for trimming doors. I can router out recesses for hinges in 10 seconds as the bearing runs against the rectangular hole. I will try to upload pics of my setup as others may find it useful. I also have purpose made trestles to hold doors vertical and horizontal when trimming to length and width.
    Jitender likes this.
  11. Jitender
    Jitender Screwfix Select
    I'll be quite interested in seeing the jigs. I made a hinge jig last year, in 'projects' thread.
    Used it to hang over 8 doors, I used a template cutter with a bearing mounted. Just when I did the last one, the sides wore out so jig is useless now. Think it is much better to use a guide bush rather than being as will be less wear and tear on the jigs.
    I did buy a hinge jig from Axminister last but not got round to using it, unpacked it yesterday and took me a while to understand it.
    The jig I made was so easy to use and fool proof so will make up again, or use existing to cut the template bigger.
  12. KIAB
    KIAB Super Member
  13. Jitender
  14. KIAB
    KIAB Super Member
  15. Jitender
    Getting the hang of this jig, used for a few door now and works well.
    Watching the video helps, as you have to align the jig to the '0' mark.
    Just have to remember to offset the jig 2mm from edge of hinge, ordered a 12mm cutter for use in a 16mm guide bush.
    Few improvements could have been made, i.e have a no tools hinge adjustment. Need to use a screwdriver to adjust the width of hinge, looking at putting in some threaded wing nuts.
    Don't think I will use it in the door lining mode as easier just to recess hinges using a palm router.
    KIAB likes this.
  16. KIAB
    KIAB Super Member
    Found that jig so fiddlely & annoying to set up.
  17. Jitender
    Must admit took me a while to work out how to use it, as well as assemble it.
  18. Jitender
    I've got the Kastsu router which is like a copy of the Makita palm router. pretty good little router but am tempted to look for the cordless one as I have the battery platform, but the smaller Bosch one look much lighter and controllable. Unfortunately I don't have any Bosch 12v tools, unless Milwaukee bring out a router,but don't thick they make this as I don have there drill and driver in 12V.
  19. KIAB
    KIAB Super Member
    The 240v Bosch GKF600 palm router is total carp!
    Got to buy Bosch adaptor to use guide bush, & guide bushes have to be Bosch, as they only ones that fit, you can buy a uni base to use other bushes, so I bought a Kastsu router & a plunge base.
  20. Jitender
    May get the plunge base for the Kasus as well. Find it can be trick setting the depth. Especially with hinges as hinge won't lie flat, on the knuckle. Also the fixed base that's supplied hinders the sight of the bit so hard to see when cutting delicate stuff.
    AlvyChippy likes this.
