Some time ago, I made a toolchest from pine. The wood was well dry when it was made, and it was finished with a coat of Colron wood stain, and three coats of yacht varnish (as it would eventually reside in a damp garage). Once made, it actually stayed in the house for about six months. During this time, all the brassware associated with the inside of the box (screws, hinges, saw backs etc) developed a sticky green film on it's surface. The external brassware didn't. This film came off easily enough with fine wire wool and WD40, and the brass looked like new again. Now the box is finally in the garage, and the green film is coming back again. I don't think it is due to the atmosphere that the box is kept in, as it has happened in both dry and damp conditions. As I say, the film can be removed, and the brass looks as good as new. Any of you experts out there got any ideas?? Any help would be appreciated
If you clean it up you can then spray it with a clear metal lacquer which will keep the verdigris away
Thanks both for the advice, I will spray with laquer and see how it goes. Apologies Wolf if it was a stupid question!!!!!
no not really, quite a lot of people do not realise that the timber will absorb moisture from the air within a cabinet/box etc, and later release it when the conditions are right, especially after they have put said box etc up on bricks or what ever!!!!!my dad was good at that one!!!!! regards matt
