Hello, Looking at laying a patio onto a concrete base - pic attached. Will be using 600mm x 600mm x 20mm Porcelain slabs. Whats the best method to lay these? Do we apply a 30mm mortar mix, then lay directly on top? Also we would need to cut a small section for the down pipe drainage area, is this ok to cut with a handheld angle grinder? Thanks Matt
