Peep hole in narrow panel door (15mm)
Discussion in 'Carpenters' Talk' started by MrLM, Jul 28, 2021.
Tags:
  1. MrLM
    MrLM New Member
    Hi guys, as per the title I can't seem to find a solution for a peep hole. My front door middle section where I want to have a peep hole is mere 15mm. Any suggestions, please?
  2. Muzungu
    Muzungu Screwfix Select
    Can you not just add a spacer section that matches the door?
    MrLM likes this.
  3. DIYDave.
    DIYDave. Screwfix Select
    Door viewers are available to fit a range of door thicknesses / from around 16mm I’ve seen
    Google will be your friend here …… probably followed by Amazon !
    MrLM likes this.
