I've recently stumbled across a company called PFT Duburring that will deburr copper /plastic and iron pipes for you in bulk other services include swaging and cutting pipe to size. They send your order via Tuffnells or you can pick it via their workshop. Now the big question is Does anyone really need a service like this?
How confident are you in your pipe-layouts? I would never be sufficiently confident in mine to be able to get everything cut and bent off-site.
This surely can’t be for domestic jobs, I have spent a lot of my working life in pipework fabrication shops, we usually had in house cutting bays where the cutter gets the cut list direct from the office worked out off the drawings by some guy that had all the relevant info fitting sizes etc, but I’m talking steel pipe from 2” upto perhaps 36”, and in very large quantities Also I have worked on jobs where large swept bends are required on very lightwall stainless this was achieved by packing the pipe with fine sand prior to pulling, this was usually contracted out to specialist companies
