pipe freezing kit
Discussion in 'Plumbers' Talk' started by evo nut, Feb 11, 2010.
  1. evo nut
    evo nut New Member
    Hi
    trying to change the mixer tap on my sink.
    turned the cold off no problem but no way of turning the hot off so was going to freeze the pipe.
    obvoiosly i haven't run the tape so the water in the pipe is cold but will this work?
    i need to fix a ball o fix / isolating value on so i won't be long i hope!
    any thoughts?
    many thanks
    evo nut
  2. spongeblob
    spongeblob New Member
    turn cold off,run hot water till it stops,fit iso, turn on.Sorted
  3. spanners2001uk
    spanners2001uk New Member
    Put on your freezing pipe jacket, turn on your gas, wait till you hear a click from the pipe, about 4 mins, turn on your tap, if no water comes out, cut your pipe and fit your vlave.
