Pipe Identification
Discussion in 'Plumbers' Talk' started by Wishidneverstarted, Oct 12, 2018.
  1. I've started worked on kitchen dining room at my property and have found this random pipe within the floor of the under stairs cupboard which is off the kitchen
    Pipe is approx 1 1/4 outside diameter and iron, wrapped in Denso(?) tape lower down
    It was capped off at about the level of the original quarry tiles which had been tiled over at some point before I moved in.
    House is 1920's 'ish
    Markings on the cap are WASK and 1"
    Its not the current elec, gas or water supply as I know where they run.
    Old water supply pipe?
    Cheers
  2. KIAB
    KIAB Super Member
    Compression fitting for a 1" pipe,probably gas, outside chance it's water.
  3. Unless it is Tee'd into the current incoming gas underground it isn't the gas as I know (or can currently see due to no ceilings) where all the gas pipes in the house run from the external meter box.
    I need to remove it or at least lower it to get the quarry tiles back over the top, I'd really rather not simply undo it and hope nothing comes out.
    House did have old gas lights so could be the feed for them? were they mains fed or old bottled gas? or as you say could be old water supply.
  4. Dave does Gas
    Dave does Gas Screwfix Select
    You could call your gas supplier who can arrange for your local gas networks company to investigate for you. If its an incomming gas main it will be under high pressure and only they can deal with that. It is most likely a redundant gas pipe. We routinly cap these to prevent smells in the house as old gas pipes dont smell too good.
  5. just pumps
    just pumps Screwfix Select
    Old supply for a gas fire?
  6. retiredsparks
    retiredsparks Super Member
    OP
    Have you ever heard anyone whisper
    "up periscope"?
    RS
    blarblarblarblar likes this.
  7. Richard_
    Richard_ Active Member
    WASK is a brand of gas fittings.
    Probably an old supply, maybe to an old meter location? Best get the gas company to check it.
    It's not an old gas fires supply, that would be supplied with lead or copper about the size your finger.
  8. Heat
    Heat Screwfix Select
    It perhaps is an old gas pipe that might have supplied kitchen gas appliances.
    In NI you would have got old “Town gas” back in the day when no natural gas was piped.
    Gas coin meter below the stairs to supply kitchen
  9. Thanks all for suggestions. Could be the old gas light supply, not uncovered any old lead piping heading in that direction when removed the old plaster from the walls or ceilings however that's not to say it wasn't already removed as I believe the old kitchen area wasn't originally plastered as the bricks are painted under the modern plaster.
    I'll investigate further probably with the gas company.
    Heat likes this.
  10. Just to close this.
    Gas company has just been round and confirmed its on old gas supply pipe (probably from the gas lights era) and is dead, engineer just pulled the cap off without undoing it even!
    Happy for me to cut it down lower as required for the floor finish but just put the cap back on it.
    Richard_ likes this.
  11. rogerk101
    rogerk101 Screwfix Select
    Did they charge you for their visit?
  12. No charge
    rogerk101 likes this.
  13. KIAB
    KIAB Super Member
    Good to have a update.:)
  14. Isitreally
    Isitreally Super Member
    I have similar under a kitchen unit, mine is a gas pipe capped off that run an old fire when there was a wall there and it was two rooms.
