pipe query
Discussion in 'Plumbers' Talk' started by Foxer7, May 23, 2020.
  1. Foxer7
    Foxer7 Member
    Hi guys I’ve got a soil pipe coming out of concrete in a bathroom and due to a redesign is it not needed anymore (see image) so I was planning on capping it just below floor level and covering with screed when I went to the builders merchants the only thing they have to cap a cut soil pipe was a collar and closer which is huge so that means a lot of kangoing has anybody got something that may be smaller and a little less work
    Cheers
  2. candoabitofmoststuff
    I don't know what the regs are... but couldn't you just use the closer without the collar?
    Cando
  3. Abrickie
    Abrickie Super Member
    McAlpine DC4-BL Screwfix sell them
  4. kiaora
    kiaora Screwfix Select
    Hi
    It’s possible, to get a good grip on the pipe and simple pull it out the fitting lower down ? then just fit the plug on the hole!
    Just a thought
    good luck
    Peter
  5. Foxer7
    Foxer7 Member
    The pipe diameter and closer are the same size that was my plan first day but seems the collar is needed
  6. Foxer7
    Foxer7 Member
    Unfortunately no as the radon barrier is attached and below concrete is 4 inch insulation etc thanks though
  7. Foxer7
    Foxer7 Member
    This could be a goer cheers you reckon that would seal it permanently below floor level for good
  8. Abrickie
    Oh yes ;)
  9. Foxer7
    Foxer7 Member
    Excellent cheers
