PIR sensor installation
Discussion in 'Electricians' Talk' started by Farabaldy, Oct 13, 2021.
  1. Farabaldy
    Farabaldy New Member
    I am looking at adding PIR sensors all over my house to control in door LED lighting, I live in a bungalow so all sensors are going to be fitted to the roof/loft space floor. I have tried to find sensors that are fine for me to lay 400mm of insulation on top of but can not find this listed anywhere and any manufacturer I contact is very non committal. My understanding is that PIR sensors do not run hot and so it should not be an issue covering them with insulation however I am wondering what the general consensus is on doing this or if there is any reason I should not be doing it.
    On a similar note do you have any recommendations of flush mount ones which are reliable without breaking the bank, I see them ranging from around £10 - £80 but given I need around 20 I don't want to pay more than I need to.
    Thanks
  2. Fusebox Wales
    Fusebox Wales Member
    Farabaldy likes this.
  3. bright_Spark
    bright_Spark Screwfix Select
    Just place small plant pots over the top of them then tear the insulation at the top of the breather holes. This will give sufficient breathing/cooling space and much cheaper than fire hoods.
