Plaster board behind or on top of shower tray
Discussion in 'Plumbers' Talk' started by Deborah s, Sep 23, 2021.
  1. Deborah s
    Deborah s New Member
    Hi, What is better the plaster board to go on top of the shower tray or for the plumber to leave a gap for the board to slide behind the shower tray? What's the pros and cons?
  2. pppmacca43
    pppmacca43 Super Member
    I would have the tray push upto the board, with a bead of silicone on the flat back edges, and then a small bead around the top. Then tile over the tray with a bead of silicone to finish
    If using plasterboard it should really be tanked before tiling, I used a BAL tanking kit, simple instructions and easy enough to do.
    CGN likes this.
  3. Deborah s
    Hes already put the tray in up to the 3 by 2 and not left a gap for the plaster board. He said its fine to board up to tray and better because if there is ever a leak it will run into the tray?? I just want it done the best way am I best asking him to move the tray so there is a gap?
  4. koolpc
    koolpc Screwfix Select
    Should have used a better board. I wouldnt use plasterboard myself. Plus, any water that may get behind the sealant / tiles could "wick' up the plasterboard when it is sat on top of the tray!
    FlyByNight and just pumps like this.
  5. Deborah s
    Hi its not been boarded yet the plumber has put the tray up to the 3 by 2 and not left a gap for the plaster board. The board we where getting is the green board. What board would you suggest?
  6. pppmacca43
    Not the way I would do it. If using green plasterboard I would use a tanking kit on it as well. I wouldn’t have the board whether it’s plasterboard or cement board sat on top of the tray, I’d have the tray pushed up to it, siliconed, tiled then siliconed again.
    Everyone has there own ways though.
    CGN and Deborah s like this.
  7. Deborah s
    So would you use like aqua board
  8. Deborah s
    Everyone I have spoken to have said they would do the same as you. But the plumber is saying it it wont matter its only 10mm difference and it would be better because if there is a leak it will go onto the tray rather than behind the tray.
  9. pppmacca43
    There are all sorts of different boards instead of plasterboard that can be used now, green board will be ok if tanked imo but with the tray pushed upto it rather than sat on the tray.
    Deborah s likes this.
  10. pppmacca43
    I would say you normally push it upto the board and silicone, then tile and silicone to give it two lines of defence against going below.
  11. dcox
    dcox Screwfix Select
    Boards need to go in first - I’d use a cement board like Hardibacker in wet areas. They don’t go mushy if water manages to get to it.
    Having the boards in first gives a continuous surface to stick the sides of the tray to.
    Check the adjustments available on your enclosure. If the plasterboard sits on the tray edge with tiles over it may mean the enclosure can’t be fitted properly.
    Just guessing, but perhaps your fitter just doesn’t want to get held up waiting for the plasterboard to be fitted.
    pppmacca43 and Deborah s like this.
  12. Deborah s
    Yes I think thats the case but if he had left the gap the plasterer could have just slid the board behind. Also the tray edge is going to be shorter now due to the board plaster then tile
  13. terrymac
    terrymac Screwfix Select
    How many walls is your tray going to be in contact with ,two or three ?
  14. FlyByNight
    FlyByNight Screwfix Select
    Cement board such as Hardie Backer - way better than any plasterboard especially in your situation.
    And make sure there is a good silicon seal at the bottome of whatever you use
  15. John the plumber31
    John the plumber31 Active Member
    Hardie backer for me aswell( that’s what I always use)
  16. Deborah s
    2
  17. Deborah s
    would that just be used for the shower area and rest of the bathroom green board?
  18. koolpc
    Yes. Tell the plumber what 'you' want. You are paying him. Do it the right way now.
    FlyByNight and pppmacca43 like this.
  19. CGN
    CGN Screwfix Select
    The other potential problem is when you come to fit the enclosure. They are designed to work with a layer of tiles, but you’ve got the additional thickness of Pb as well. May be ok, maybe not. I always board, then fit the tray. Rarely use Pb, but if so, it gets tanked. Hardiebacker is better, but there are a few more modern equivalents that are far superior and nicer to work with.
    FlyByNight, pppmacca43 and koolpc like this.
