Plaster skim bathroom wall meets floor tiles
Discussion in 'Other Trades Talk' started by baracus, Aug 15, 2018.
  1. baracus
    baracus Member
    Hello,
    A plasterers question but how do you finish a plastered wall to a tiled floor in a bathroom?
    Is there a certain bead to use, leaving a small gap between tile and bead or do you normall skim all the way down to the tiles?
    Thanks
  2. Jord86
    Jord86 Screwfix Select
    You would normally skim the walls before tiling the floor, but in this scenario either fix wooden skirting at the intersection, tiles stuck onto the bottom of the wall acting as a skirting, or just skim down to the floor and leave as it is.
  3. CGN
    CGN Screwfix Select
    You can use a shadow gap bead, but you fit these before boarding.
  4. DIY womble
    DIY womble Well-Known Member
    If it's too late for shadow bead use a stop end bead
