Plasterboard blown screws
Discussion in 'Painters' Talk' started by Damoville, Nov 21, 2020.
  1. Damoville
    Damoville New Member
    Hi all,
    I have a number of areas in our dining room where the plaster keeps falling away because of the screw underneath. Normal filler does not seem to work very well.
    Any advice would be welcome.
    thanks
    damoville
  2. AnotherTopJob
    AnotherTopJob Active Member
    If the screw isn't tight against the board, then there will be slight moment which will push any filler out.
    If the screw can't be tightened, consider adding another one nearby.
  3. Wayners
    Wayners Screwfix Select
    Add more screws along. You will cause more popping of the old ones as you go. Fill, sand and paint
  4. Damoville
    Thanks
    Wayners likes this.
  5. Jord86
    Jord86 Screwfix Select
    That looks like a clout nail rather than a screw, use a hole punch and a hammer to punch it in gently if that's the case, scrape out any loose, little bit of PVA then fill over the top. As per above, add more screws either side first to take up any gap.
    Damoville likes this.
  6. Damoville
    Thanks
    thank you
    Wayners likes this.
