plasterboard question?
Discussion in 'Builders' Talk' started by cosworth, Mar 12, 2008.
  1. cosworth
    cosworth New Member
    could anyone tell me what the regs are on plasterboard on a ceiling please.(if there is a reg)ive been under the impression its 12mm on ceilings and either 9.5 or 12mm on studs.
    thanks
  2. J.T. Builders Ltd
    J.T. Builders Ltd New Member
    Normal is 12.5mm
    unless there is a steel in the ceiling, then you need fire check.
    i'm guessing this is in a house and not flats?
  3. bigjules
    bigjules New Member
    Normal is 12.5mm
    fire check.
    Unless joists are at greater centres than 400mm then 15mm plasterboard.
  4. Mr GrimNasty
    Mr GrimNasty Active Member
    And fireboard or double 12.5 joints overlapped in some locations I think (stairwell/kitchen????).
  5. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Think that may be only in garage with habitable room above!!!!
    Mr. Handyandy - really
  6. nearnwales
    nearnwales Member
    Normal is 12.5mm
    need
    fire check.
    Unless joists are at greater centers than 400mm then
    15mm plasterboard.
    You can use 12.5mm with 600mm centers can't you
  7. kaintheo
    kaintheo New Member
    You can use 12.5mm at 600 centres but you must have noggins at 1200 to give it a fixing along it's length to prevent sagging.
    In practice its faster and easier to install 15mm and this is what I,m pushing for on my next site.
    9.5mm is not suitable for walls and is seldom used now on ceilings either.
  8. cosworth
    cosworth New Member
    thanks.
    yeh its a house not flat.just reboarded my parents kitchen ceiling.
  9. ­
    ­ New Member
    That's right, my suppliers have increased the price of 9.5 to equal the 12.5 as a way to stop people asking for it. They will then phase it out completely.
  10. lojo
    lojo New Member
    some bcos are ok with 9.5 on ceilings, but id always use 12.5 unless your patching and only 9.5 matches
