Hi all,
I'm planning on making our external single brick garage into a gym, to do so, I'll be adding plasterboard and plastering the walls and ceiling, I'll be adding a damp proof protection tot he conrete floor and then the foam gym flooring squares on top. i'll also be building a stud wall to seperate the gym and storage part of the garage.
I'm putting a list of stuff to buy together, and when I'm researching what to use, I'm seeing multiple conflicting recommendations, so I'm hoping someone can help!
For the walls/ceiling, I was thinking of doing the below in this order :
-Damp Proof Membrane or Paint (against the brick wall)
-25mmx50mm Battens (I'll be treating the battens and adding some form of waterproofing tape on the floor battens)
-Insulation between battens (I've found a reasonably priced Acoustic Roll insulation)
-Vapour Barrier
-Plasterboard (Either a standard or moisture resistant plasterboard)
-Plaster
-Paint
Would this be the correct/best way to go about it? and when it comes to insulation, can I use any cheap insulation since I'm doing both a damp proof membrane and vapour barrier?
Any help, advice or corrections are greatly appreciated!
-Vapour Barrier
-Plaster
-Paint
